What MP3 players work through the USB on a 2012 Civic?
Discussion in 'Navigation, Security Systems, & Electrical' started by desiguyinnc, Jun 26, 2011.
  1. desiguyinnc
    desiguyinnc Well-Known Member
    78
    Long Island, NY
    Vehicle Model:
    Civic LX
    Body Style:
    My old ipod broke and I was wondering if the ipod shuffle would work through the USB slot. I don't really feel like spending a lot on a new ipod....are there any cheaper MP3 players that are compatible with the USB slot? I tried hooking up my hard drive it and that didnt work.
  2. webby
    • 2017 Toys For Tots
    webby Administrator
    46,944
    from honda -
    I've had a few different mp3 players hooked up without issue. You also have the MP3/Auxiliary Input Jack you can use.
  3. s2k
    s2k Well-Known Member
    5
    Droid phones should generically work. When you connect the USB, you will need to ensure it is not in "Charge Only" mode. If you select "Filesystem" or something similar, the Droid will re-mount as what will appear to be a USB thumb drive to your Civic and you will be good to go.
    Or, just use the Bluetooth. I'm using Winamp on my phone, and it immediately started playing music when I hit "Aux" on the dash - in the middle of the song I had been listening to with my headphones earlier, no less. Honda's Bluetooth is definitely superior to Toyota's.
    webby likes this.
  4. webby
    webby Administrator
    46,944
    Thank you for that ^^^. I've not had a droid owner confirm that
  5. s2k
    5
    I can confirm that Bluetooth works flawlessly for both music and phone calls on my Evo 3D. It even blew my salesman away. It also works fine as a USB device.
    I prefer the Bluetooth, as it's one less cable to connect. Also, I don't know what would happen if I was listening through the USB and got a phone call...
    webby likes this.
  6. Ian Robertson
    Ian Robertson Well-Known Member
    118
    Austin, TX
    Ya know what's a lot cheaper than a new mp3 player? Just get a 8 or 16 gig thumb drive from walmart, fill it with mp3s and plug THAT in. I mean, if you're going to get an mp3 player, go for it, but the IMID will read directly from a flash media drive like a thumb drive automatically. SO much less expensive.
    Flippercon, Sean Prunka and webby like this.
  7. webby
    webby Administrator
    46,944
    That is a great idea for people. They wouldn't be able to listen to music on headphones with that route, but that is a cheap method of getting a lot of tunes in the car!
    Ian Robertson likes this.
  8. duerrs
    duerrs Well-Known Member
    13
    Kinnelon, NJ
    I'm wondering if my 120 gig zune will work? Seems like zune is the red headed step child of the mp3 world.
  9. Noel
    Noel Well-Known Member
    5
    I have connected my iPod Touch and it works great! Occasionally, the iMid will report it is unsupported and I have to disconnect and reconnect the iTouch, but it continues playing from the same point in the song. I soon plan to try the USB thumbdrive option and the bluetooth as well, will report back after I do.
  10. webby
    webby Administrator
    46,944
    I haven't tried it on the 9th, but zunes did not work in the 8th generation civic. People with zunes had to use them off the aux plug. It wouldn't work off the usb.
  11. dentrecords
    • Supporting Member
    dentrecords Polar Bear
    3,252
    [​IMG]
    webby likes this.
  12. chano
    chano Well-Known Member
    67
    Midland,Tx
    Ipod works, HTC EVO works, and I just got a PNY 16g
    Sent from my PC36100 using Tapatalk
  13. webby
    webby Administrator
    46,944
    [​IMG]
  14. duerrs
    13
    Kinnelon, NJ
    i'd love to be able to use the zune from the usb port but i guess i should not hold my breath
  15. brown_bear
    brown_bear Well-Known Member
    1,003
    Reston, Virginia
    Vehicle Model:
    Body Style:
    my ipod touch works fine but i get some grainy sound with some songs...might try a different cable...
  16. dentrecords
    • Supporting Member
    3,252
    they probably aren't encoded at a high bitrate.
  17. brown_bear
    1,003
    Reston, Virginia
    Vehicle Model:
    Body Style:
    hmmm..i'll have to check that out.....
  18. K20Matt
    K20Matt Member
    9
    Roanoke Rapids, NC
    Vehicle Model:
    Honda
    Body Style:
    Civic Si Coupe
    My girlfriends iPhone 4S will not work on the USB port on her 2012 FB6. I have a 2010 FG2 and my USB port will charge hers but will not play music through the port. So we use a AUX cable for music when using her phone.
    I'm still trying to figure out why her 4S will not even charge when we tried it this weekend. Note the car was bought used and has a nice Clarion navi unit installed. I'm wondering if the USB was plugged into the back of the radio when installed. I know the previous owner and was told that Honda installed the radio.
    Is there anything else I should try before snatching the dash off and checking the USB plug?
  19. Flippercon
    Flippercon Well-Known Member
    1,697
    Virginia Beach, VA
    Vehicle Model:
    Body Style:
    Let me know if that PNY works. I had no luck with a 32g PNY
Share This Page
