What Oil & Filter combo do you run? (And on what engine)
Discussion in 'Mechanical Problems & Technical Chat' started by Blackeagle, Aug 25, 2018.
  1. Blackeagle
    Blackeagle Member
    32
    Arizona
    Vehicle Model:
    Si
    Body Style:
    looking to find out what you guys run on your 9th gens. Not trying to start a "What oil is best" or "AMSOIL or nothing!" argument either, just the combo of what you're running.
  2. squiggy
    • 2018 Toys For Tots
    squiggy Cartographer
    10,833
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Don't run Amsoil. Multiple Blackstone tests in a row were not very favorable.
    SpnFed_CivicSi likes this.
  3. Sarcras
    • Supporting Member
    Sarcras Supporting Member
    1,129
    North Dakota
    Vehicle Model:
    Body Style:
    FB6
    I have used Pennzoil Platinum for all but my last oil change. Most recent was Royal Purple and always Honda oil filter for the k24.
  4. homegrown
    homegrown Well-Known Member
    122
    Vehicle Model:
    Body Style:
    FB6 Sedan
    I’ve been using Idemitsu Zepro 0W-20 with a Honda Filtech filter in/on my K24.
  5. SpnFed_CivicSi
    SpnFed_CivicSi Well-Known Member
    115
    Florida
    Vehicle Model:
    Si
    Body Style:
    I use Valvoline full syn 0w-20 and Honda filter for my K24z7
  6. Blackeagle
    Blackeagle Member
    32
    Arizona
    Vehicle Model:
    Si
    Body Style:
    Are all of you running the AO1 (I believe that's the Filtech) Honda filter? and what OCI are you going on those?
  7. freggie
    freggie Well-Known Member
    101
    Hesperia, California
    Pennzoil Ultra Platinum and Purolator One oil filter. I had oil consumption with the regular Pennzoil Platinum, i drive the car a bit hard...
  8. ron v
    ron v The good, the bad, and the booty
    3,453
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Coupe and hatch
    Royal purple and oem filter.
  9. Sarcras
    • Supporting Member
    1,129
    North Dakota
    Vehicle Model:
    Body Style:
    FB6
  10. bfaided1984
    bfaided1984 Active Member
    84
    DFW
    Vehicle Model:
    Civic
    Body Style:
    sedan
    Mobile 1 full synthetic, wix filters.
  11. Blackeagle
    Blackeagle Member
    32
    Arizona
    Vehicle Model:
    Si
    Body Style:
    EP or AFE Mobil 1? and Wix Standard or XP?
  12. bfaided1984
    84
    DFW
    Vehicle Model:
    Civic
    Body Style:
    sedan
    Uhhh, whatever regular mobile 1 is so AFE? and the black wix filters.
  13. Flightmaster127
    • Supporting Member
    Flightmaster127 Supporting Member
    3,471
    Delaware
    Vehicle Model:
    Body Style:
    Pennzoil Ultra Platinum and OEM Honda A01 filter.
  14. DMS24
    DMS24 Well-Known Member
    127
    Nevada, USA
    Vehicle Model:
    EX
    Body Style:
    For my R18 after factory fill used Mobil1 AFE and FRAM Ultra. Now exclusively using Mobil1 EP and FRAM Ultra. Been considering AMSOIL XL going forward though with Wix (non XP). Basically I just use the same oil/filter combo in our family Hondas.
  15. Sinub
    Sinub Well-Known Member
    304
    Southern California
    Vehicle Model:
    Body Style:
    I use Amsoil OE oil line with an OEM Honda filter. Currently at 80k with no issues, no oil leaks on my 2012 Civic Si. The engine still looks clean from what I can see from the oil cap.
    I swear by their tranny fluid on any Honda. I have it on my 2012 Civic Si and my 1987 Crx Si and notice smoother shifting over Honda Trans oil. I researched before determining on Amsoil and read nothing but good things and saw only good things about their lab results. I'm surprised squiggy has seen bad results though.
    Honestly any oil is good if you're not beating you're car and you're changing the oil consistently. If you're a spirited driver I would recommend Puroil, Amsoil, or Motul. They'll all suffice and last longer than your standard oils.
    I use Signature Amsoil oil on my 87 Crx Si for the track and usually do two track days and some driving in between before changing the oil (also using an OEM Honda filter). It's over 250k miles on the original motor (rebuilt top end by choice).
    I'll admit I'm an Amsoil dealer but I don't purely use Amsoil products such as their Brake fluid and fuel injector cleaners and such. For engine oil and Honda tranny oil, I personally recommend it though.
    Sent from my ASUS_A006 using Tapatalk
  16. Blackeagle
    Blackeagle Member
    32
    Arizona
    Vehicle Model:
    Si
    Body Style:
    Sinub,
    I used to be a preferred customer too but my cost benefit was erased when a local store started carrying Amsoil on the shelf at preferred customer pricing. I mostly use Amsoil for my powersports vehicles and I've started using Valvoline since my 8th gen burned oil with any other brand, mostly just trying to get input since some engines seem to favor the density and additives of some oils over others. Being in Arizona between the heat and dust I don't trust extended intervals enough to do 1 year/12-15k changes either to justify the cost of amsoil in my cars.
    I tried using Amsoil Synchromesh in my 8th gen si and it was way too thick in the winter (lows in 30s, not below 0 or anything) and even in the summer made my 3rd gear notch almost unbearable. Do our transmissions or LSD's have brass in them? I read somewhere (albiet a while ago) that the additives in Amsoil's MTF don't play nice with brass components which is why the Honda MTF seems to be the go-to for most people as it's brass safe.
  17. ron v
    3,453
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Coupe and hatch
    I think synchros are brass.
  18. Sinub
    304
    Southern California
    Vehicle Model:
    Body Style:
    The synchros are brass as with most transmissions. My 87 Crx has brass synchro, most B series has brass and k series, as far as I know, come with brass synchros front factory.
    I know people with 8th gens running Amsoil. They have no issues same with myself.
    ron v likes this.
  19. ron v
    3,453
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Coupe and hatch
    Amsoil synchromesh?
  20. Sinub
    304
    Southern California
    Vehicle Model:
    Body Style:
    Yes. I should have been more specific. I've also heard good stuff about the Pennzoil Syncromesh, but I love the Amsoil synchromesh and have no complaints to have wanted to try the PS stuff.
Share This Page
