- 55,469
- 23,791
What does this mean? I don’t understand your questionSo should I move the tires forward and forward backwards.
http://9thcivic.com/forum/threads/18x8-5-20-offset-on-2012-civic-si-sedan.12783/#post-332364How does 18x8.5 with a 20 offset look like? Rims I like are in that size only. Am I looking at flush? Or a lil poke?
Hard to say when you are that low. That wheel spec will push out about 1/2" from stock. Do you have that much clearance where you are tucking?looking at Ssr type C’s 17x8 +46. I shouldn’t have a problem right?
im pretty low at the moment the rear is slightly tucking tire rn on completely stock 2013 set up (oem Wheel and tire)
i plan to run my stock 215/45 tires for a lil n then do 225/45
that is a setup that a lot of people run without issue17x8.5 +35
