Wheel Hop at drag strip!!
Discussion in 'Forced Induction & Nitrous Oxide' started by Garrett Allison, Aug 8, 2019.
  1. Garrett Allison
    Garrett Allison New Member
    17
    I have awful wheel hop at the drag strip and I have all basically solid mounts, traction bar, upper strut bar, coilovers adjusted to stiff, and 235/40/17 federal rs-rr and I wheel hop unbelievably. Does anyone know how to get rid of it?!?!?
  2. dpetro1
    dpetro1 Well-Known Member
    407
    Catonsville, MD
    What is the rest of your setup? How much power is the car making?
    From what I can see, the rs-rr is an all season, road race type tire?? Not to mention you are running a low profile.
    You can try to drop the pressure but likely better off with a slick or drag radial on a smaller wheel.
  3. Garrett Allison
    17
    I make 220wheel right now but I’m about to be making 260-270wheel and I need the problem solved
  4. Garrett Allison
    17
  5. Garrett Allison
    17
    Oh and how do I drop the tire pressure without sitting off the tpms because then i can’t disable traction control because of low tire pressure
  6. webby
    • 2018 Toys For Tots
    webby Administrator
    49,831
  7. squiggy
    squiggy Cartographer
    10,838
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Traction balls might help. I am at the 220-230 whp range with a few mounts and Michelin PSS and still have wheel hop even when the tires are warmed up.
  8. sunofwolf
    sunofwolf Well-Known Member
    781
    Vehicle Model:
    honda SI 2013 35% tinted Hondata coupe 136+mph! SRT-4 180+! VFR-800-11750 rpm 10.9 1/4 130+! Neon 2001!
    Body Style:
    coupe
    :hyper:gee wheel hop at only 220hp, my srt-4 is making 275hp at the wheel it doesn't work at 1st gear
    I can't get going till 2nd gear and 20 mph. Ya that stupid tpms really suks that ca came up with making it a pain in the *** to switch rims is another thing I don't like either. Perhaps try 2nd gear at take off.
  9. Garrett Allison
    17
  10. mySIck
    mySIck Well-Known Member
    1,137
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
Share This Page
