XD700/5v2 Question
clumsywob
Member
2
1
I just installed the following:
Car: 2015 Civic SI Sedan w/Nav
HU: Factory Nav
Fronts: Focal Performance PS 165V components
Rears: JBL CLUB 6520
Sub: Rockford Fosgate P1
Amp: JL Audio XD700/5v2
The P1 is temporary until I figure out which direction I want to go sub wise. My boss just gave me 2 JL Audio W1's in a JL Audio box that I'd like to hook up. My question is, can I use two subs with my existing setup, or would I need add an additional amp?
Also, any recommended settings on the XD700/5v2 for my setup?
Thanks in advance!
You should get yourself another amp to run the w1's. Or ...remove the p1, and run the w1's on your current setup.
Sorry, I should have specified, the P1 will be removed, should I decided to use the two W1's
Are the speakers set up for 2 or 4 ohms?
I will have to verify this when I get back to my car. A buddy of mine actually did the wiring, so I'm not 100% sure
