Mike's boosted build
mySIck
1,507
FT. Bragg, NC
Civic SI
Current build list for my 2013 Civic SI
Current Turbo build:
hondata Flash Pro- tuned by Rob Rainer
PRL stage 2 turbo kit
PT6262 ball bearing
Comp clutch stage 4 1620
COMP CLUTCH flywheel forged lightweight steel
70A Hasport motor mount kit
Full-Race Traction ball
DW1000cc injectors
Ktuner 4 bar MAP sensor
Full-Race 3" exhaust
RBC intake manifold- PRL swap kit
Axion industries race catch can
Acuity Fuel rail with Marshall gauge
Walbro 450 Fuel pump
Acuity fuel regulator
Custom vibrant fuel return system(Axion)
Billet steel T3 turbo manifold 46mm V-Band wastegate inlet flang
304 stainless steel dump tube
PRL core divided end-tank intercooler
PRL 4" intake with filter
Suspension:
D2 RS coilovers
Interior:
AEM boost controller
Perrin gauge pod
Kenwood Headunit
Old N/A build
Full-Race Catless DP
P2R TBS
Skunk2 CAI
Hasport 62A rear motor mount
Futurama(wishlist):
Drivetrain:
K-Tuned slave cylinder
K-Tuned CMC
Acuity shifter cable bushings
mFactory close ratio gear set 1-6
Motor:
Carrillo Pro-A rods
CP piston 87.5mm
CSS bottom end
Supertech Valve's & Springs
Skunk2 ultra race intake manifold
Fuel:
FIC 1100CC injectors
Interior:
Acuity adjustable short shifter
Brakes and suspension:
Skunk2 rear camber arms
Stoptech big brake kit
I hope soon I can provide some good upgrades for everyone.
Thank you, There is not much under my hood right now but soon I hope to ad something special soon.
Thanks bud it's a work in progress I am going to take my time with this one.
How do you like the Hasport mount? I am having trouble deciding between U62A or U70A.
I like it I could tell a deference with the 62A it feels solid. There is a small amount of vibration in the car too. But I think the 62A is good enough for basic performance upgrade.
