2015 Si strut help!!!
Discussion in 'Suspension And Brakes' started by Talizabeth, Oct 11, 2020.
  1. Talizabeth
    Talizabeth New Member
    4
    Hey everyone!! I’ve been having a super hard time trying to find a replacement strut assembly for my 2015 si. My right spring is cracked and they recommended replacing the full strut assembly. The dealership told me they couldn’t currently order the parts in so I’m really not sure what to do. I’ve ordered off of 2 different sites that both said the parts were compatible but after getting the parts I realized they’re not for the Si. If anyone has any ideas on where I can find springs or a whole assembly please let me know!! Cheers!
  2. webby
    • 2020 Toys For Tots
    webby Administrator
    52,113
    Talizabeth likes this.
  3. webby
    webby Administrator
    52,113
    Note that the strut is for the sedan. If you have the coupe it’s another part #
  4. Talizabeth
    4
    ok thank you! I have the coupe :p
  5. ron v
    • Supporting Member
    ron v The Forum Idiot
    5,603
    Escondido
    Vehicle Model:
    Civic
    Body Style:
    Si Coupe
    Like he said call them first. A lot of stuff is out of stock. I’m sure u can call them and give them ur vin and they’ll be able to give u exact part and stock numbers.
  6. webby
    webby Administrator
    52,113
  7. Talizabeth
    4
    Hey! Just tried ordering and they don’t ship to Canada.. any luck on any sites that do ship to Canada? I’ve been searching for these parts for months now. Seems so impossible :/
  8. webby
    webby Administrator
    52,113
    (866) 746-6386
    https://torontohondaparts.com/Default.aspx
    call and see if they have them in stock, or if they are able to order them for you
  9. squiggy
    squiggy Cartographer
    11,185
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
  10. ron v
    • Supporting Member
    5,603
    Escondido
    Vehicle Model:
    Civic
    Body Style:
    Si Coupe
    I thoughts they were only for lowered applications. I'm pretty sure you can't fit the front ones on regular stock springs.
  11. squiggy
    11,185
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    That are a full unit. Best compromise if OEM is not available.
    I would never replace a single spring, shock, strut. Always do it in pairs.
  12. ron v
    • Supporting Member
    5,603
    Escondido
    Vehicle Model:
    Civic
    Body Style:
    Si Coupe
    I’m saying I thought they weren’t made for stock level. I wouldn’t do that either lol.
  13. squiggy
    11,185
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    It might be the best option if OEM is impossible to find.
    Plus, a small drop is not a big deal unless they are running some ridiculously oversized/offset wheels.
    The drop isn't much and would actually increase handling a bit.
  14. fahnix
    fahnix Well-Known Member
    1,127
    SoCal
    Vehicle Model:
    Body Style:
    I think what he means is that the TruHarts require you to run lowering springs with a minimum of 1" drop. With OP being on stock, they would also have to buy springs along with the TruHarts.
  15. webby
    webby Administrator
    52,113
    but he'd need to get aftermarket lowering springs to work with the truharts - I think is what ron is saying. I mean, he could get full coilovers from truhart (or whatever brand), but that's also not a "cheap" solution.
  16. webby
    webby Administrator
    52,113
    fahnix beat me to it
  17. ron v
    • Supporting Member
    5,603
    Escondido
    Vehicle Model:
    Civic
    Body Style:
    Si Coupe
    yea there is no way those are fitting on stock springs. I've installed them three times and you really have to compress the shorter springs down to get the hat to fit. even on my skunk 2's which are the shortest i've dealt with it was a bit of a challenge to compress them enough.
  18. ron v
    • Supporting Member
    5,603
    Escondido
    Vehicle Model:
    Civic
    Body Style:
    Si Coupe
    Well maybe u can but I don’t know how well the combo will work.
  19. fahnix
    1,127
    SoCal
    Vehicle Model:
    Body Style:
    Nope. On the TruHart site it explicitly says that you have to run springs with at least an inch of drop. They won't work with stock springs at all.
  20. Blindeye_03
    Blindeye_03 Member
    4
    Just curious whats a good spring to run in combo with these? Are all 1" drop springs created equal?
Share This Page
