2020 Toyota Camry TRD
While I'm more of a fan with the new Camry's over the new Accord's... The Camry TRD doesn't do it for me. Not a fan of the black roof nor the spoiler...
Edit: Savagegeese is definitely straight to the point on his reviews. He doesn't sugar coat things.
One of the comments on the video:
"When you want a Toyota 86 but forgot to use a condom"
:rotfl:
It makes the same numbers as the Camry XSE V6... :rolleyes:
0-60
MPH 5.8 sec
QUARTER MILE 14.4 sec @ 99.8 mph
Okay, so if that's the case, the heck did TRD even DO?
Slap badges on it?
Mainly Appearance. (fast-and-furious body kit, which includes gloss-black lower-body add-ons—complete with a red pinstripe—and a rear wing supported by two struts.)
* The TRD's front brake rotors are 0.9 inch larger in diameter than those on the next-sportiest Camry, the XSE V-6 model
* Two-piston calipers instead of single-piston units
* Retuned the feel of the brake pedal
* Stiffer springs and stiffer
* Larger-diameter anti-roll bars (27.0 millimeters thick versus 25.4 millimeters on the XSE) increase the Camry's resistance to body roll by 44 percent in front and 67 percent in the rear.
* Stiffer underbody braces and a V-brace behind the rear seats (as a result, those seats cannot fold as they do on the regular Camry).
* TRD also fits dampers with internal return springs and revised valving compared with the units on lesser Camrys.
* TRD-specific 19-inch wheels (Not only do they look tough, each one is 3.1 pounds lighter and half an inch wider than the XSE's 19-inch rollers)
* Toyota also wraps them with Bridgestone Potenza summer tires.
