2012 Civic 1.8L
227k miles
No cool air
AC clutch does not engage
AC clutch moves freely
Both fans run when AC is "on"
Fuses are good
Relay is good
Coolant is full (shop pressurized it)
Dash thermostat adjusts normally
Max AC and AC lights come on when pressed
Is someone out there that has any idea what this could be? I lean toward the clutch but don't want to replace the compressor if that's not it.
Note: I know just the clutch can be replaced but you have to buy the whole compressor from the salvage yard so I'll just do it all instead of buying a little time.
227k miles
No cool air
Fuses are good
Relay is good
