Can the H and SI emblems on the front be removed?
Discussion in '9th Generation Civic General Discussion' started by Tony-si, Aug 15, 2020.
  1. Tony-si
    Tony-si Well-Known Member
    193
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    51,863
    Looks like 2 nuts #9 hold it from behind the grill.
    bootyluvr likes this.
  3. dpetro1
    dpetro1 Well-Known Member
    470
    Catonsville, MD
    Very common on these cars to switch the emblems.
    The front H is held on with push on metal rivet/nut so you will likely need to break them or cut them off from the back
    View: https://youtu.be/yq74zPovvCY
    The Si has a small screw holding it from the backas seen in webby's pic.
    webby likes this.
  4. Tony-si
    193
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    Ahh, thank you. He is asking $40 for each. Is that a good deal? That's for paint and clear coat.
  5. webby
    webby Administrator
    51,863
  6. Tony-si
    193
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    I am providing the emblems and they are painting the red on both si emblems and making that purple and putting a clear coat on it and then painting both H's purple as well and adding a clear coat. My buddy does wraps a little closer and can beat the price not by much but still the same procedure.
  7. webby
    webby Administrator
    51,863
    Doesn’t sound bad
    Tony-si likes this.
Share This Page
