Pauly99to17
I was looking to add some lighting, but didn't want to add too much like some footwell ambient light kits do. I just wanted to lighten up the dark tray area near the gear shifter. The way this is hooked up, the light will turn on automatically when the key is turned to the forward position and will stay on until the key is turned to the off position. I think I spent about 40 bucks in all, but 20 was for a brand new soldering iron. I still have lots of the LED light strip left. I bought a 1' strip of blue LEDs and cut the strip to the smallest possible length: 3 lights
So, to get started take out the 2 screws located on the underside of the plastic cover (see the College Hills Honda "How to" video below) and then you can begin to slowly, but firmly pull off the front cover. Get one side loose and then pull firmly from the bottom. I didn't have a proper trim tool (available at CHH for about $8) so I used a wooden paint stir stick to get some leverage on the sides to get a handhold. It is a good idea to put masking tape on the sides of your plastic when using the paint stir stick so as to protect the plastic. Once you have the cover off you will need to pinch the plastic holders and detach both plugs. In the photo below you can see that I have already cut the wire of the 12 volt plastic plug and removed it. Start the video at 35 seconds and watch up to 1 minute 04 seconds.
View: http://www.youtube.com/watch?v=TpwWiwdku3w&feature=player_embedded
Here you can see the 4 attachments on the back that hold the cover snug and the 2 plugs: 12 volt (silver) and the AUX (blue).
An old dog can new learn new tricks. I had never soldered anything before, but it's incredibly simple. I bought a soldering iron for about $20. I soldered the two wires, picked up at a local electronics place, to the connections on the LED strip light. Here's a "how to" solder video if you are like me and need to learn the basics.
Start video at 1:07 and watch up to 5:47 for soldering tips and techniques.
View: http://www.youtube.com/watch?v=RrmKpUaGvOM&feature=player_embedded
This is a close up of the LED light strip. You can see there are 6 lights showing. I cut this strip to use only 3 lights which provides plenty of light. You can cut these strips to any length you like. You just cut between any 4 black dots (every 3 lights). In this picture you see the 4 black dots in the middle of the strip shown here. The two black dots at the end is where you solder your wires. These two dots are clearly indicated as positive and negative.
I drilled a small hole in the back right corner of the plastic cover and fed the wire through.
I used a small strip of 3M tape to stick and hold the light firmly in position. Here you can see how little of the 1 foot LED strip I used (3 lights). You can see the 12 volt plastic plug that I cut and removed at the beginning as well as the 2 grommets I used to attach the wiring. The two sets of wires need to be attached to the split 12 volt wires that are in the console and "hot". Attach all 3 positive wires and all 3 negative wires and use the grommets to attach. After wiring is securely twisted into the grommets wrap them with electrical tape to be double sure that these connections will hold for the long run.
GRROOOOOVY BABY!!!!!
