billlaux
Someone posted about installing a pad in the console tray. I use the tray for my Tom Tom GPS. Didn't want to spend the big $$ for factory GPS. The Tom Tom works great and I use it a lot. I had a round piece of plastic stock cut to the size of the round mounting disk that comes with the GPS. Then I spray painted the plastic stock with flat black primer and mounted the disk on top. I used permanent double stick foam tape to mount the round stock in the tray. I plugged the charging wire in and coiled the excess to fit behind the plastic stock in the tray. Then the GPS just suctions to the mounting disk on top. Now my GPS is always available for use if I need it and easily removed by breaking the suction on the mounting disk. To hide the GPS I bought a small plastic index card box at the dollar store and cut it to fit over the GPS. Spray painted the box cover with flat black primer and even if someone looks directly in the window it is almost impossible to see the unit.
