Jericksen5
Member
- 1
- 0
My 2012 civic coupe has only been getting driven once a week since Covid started. Went to drive it last week, the low beams aren’t working. Everything else, including the high beams and DRLs are working fine, just the low beams.
I started with the basics.
- Checked all fuses, interior and exterior. Double checked for continuity. All fuses are fine.
- Replaced both low beam headlight bulbs. Yes I used the correct specification for the bulbs. Still not working.
- Replaced the headlight relay in the under hood fuse box. Still not working.
- Replaced the combo headlight/turn signal switch. Used the exact OEM replacement. Low beams still not working.
