Hopefully anyone can help.
Currently driving on 17 inch rims but I have some 18s SI rims that I purchased used. I had it wrapped in brand new michelin a/s 4 tires and thats where the problems begin.
The steering jerks left and right when driving on bumpy roads to a point where I feel very unsafe. I essentially have to grip the steering wheel tightly with both hands so I dont veer into another lane. Not only does it jerk, it feels as if the steering becomes disengaged with the tires and the steering wheel becomes very light and loose. On smooth roads, it drives fine.
After trying many suggestions from other users and failing to resolve this issue (3 tire balances, 2 alignments, front and rear suspension replaced) I finally decide to put back on my 17’s and low and behold, the problem disappears.
The issue seems to be the tires or rims, but all the tire guys have said the wheels are not bent and the tires are good.
What do you think may be causing this issue?
Specifics:
-Car: 2014 civic lx auto, 90k miles
-Car is not lowered (edit 7/12/2021, car is “kind of” lowered, I replaced the stock suspension with an OEM honda HFP (sport) suspension. Car rides stiffer and lowered by just 1/2 an inch)
-Both the 17’s and 18’s are OEM honda wheels
-17’s are 17x7 (P215/45R17) and 18’s are 18x7 (P225/40R18)
-According to honda, upsizing wheels should not be an issue and is within spec. Wheel geometry should not be an issue
-I am not using wheel spacers
-Hub was cleaned with steel wire bush and sits flush with wheel. I did not check the 18’s wheel bore so I will give it a thorough check as well. As far as I could tell, it is clean.
Specifics:
