Sold Retrofitted Headlights WITHOUT Projectors
Status
Not open for further replies.
A. G. Pym
45
EDIT: I'm dumb and forgot to mention these are off my 2012 Si sedan.
I am selling the headlights from my previous retrofit. I decided on another direction after having these in for about 8 months. I opened these and removed the projectors and used the projectors on a separate project. THESE DO NOT COME WITH PROJECTORS. Only what is explicitly stated and pictured.
I ran these without DRLs and used the bixenon function as my high beams. Due to how I sanded these, the driver's side headlight casts a little to the left of where it should, but I used them for 8 months with no issues. I've included pictures of the car driving down the road to show the beam output pattern. I just decided to do something completely different so I bought a new set and went for it. You could sand the back off a tiny bit more to bring the beam pattern back to center. The pictures of the beam pattern are with the low beams on and no other lights [no foglights, etc].
Each headlight includes both rubber caps, all 5 screws needed to hold the lens to the housing, and the bulb retaining ring for the high beam side, since you don't use the bulb retaining ring with projectors. On one of the headlights, the plastic aiming piece was stripped so I removed it. You WILL need another plastic aiming bit to run these. The Retrofit Source sells them for $5 I believe, and you can probably buy them many other places, or reuse your own.
All you need to use these headlights is the plastic aiming grommet for one headlight, and of course a set of projectors and all that stuff. They also need cleaned, as opening the headlights results in getting the butyl rubber all over the place, but goo-gone takes it right off. Nothing to my knowledge is wrong with them other than what I've stated. I literally took these off my car, opened them, took the projectors out, and then boxed them up.
I would prefer local pickup, but if nobody bites I would ship them at the buyer's expense. These are two headlights, so the box is big and accordingly heavy, so please bear that in mind.
I am located in Terre Haute, Indiana, but regularly travel to the Kokomo/Carmel/Indianapolis area.
Price is $100 picked up.
he's being real. $100 for a set of oem headlights is very cheap.
FYI for those wondering, each OEM headlight is $346.36 MSRP from Honda. That's the price for EACH SIDE. So like $700 for a set.
Is it? Or are you being sarcastic. I thought about throwing them away.
Nah man, good deal. I almost want to give you money to cover shipping to me. I want to re-do my retro with Mini H1 and this would be perfect for that.
I currently have a Mini D2S and I had to cut the hole to a bigger size to fit the projector through the reflector. So I basically need new reflectors.
@Bruce Bartlow Perfect set for your light upgrade if they will fit your coupe. If you haven't bought anything and the seller is willing to ship.....
Shipping doesn't bother me, but I'm just guessing it will be expensive. I can try to figure out some numbers for interested people.
@jasonandre had a set shipped and it was like $45 or so if my memory serves me. I think he said the package was like 15 or 16 lbs.
Thanks @Nomar06 . Really appreciate it.
How can I find out whether they will fit?
________________
That's full retail. Online discounters like www.hondapartscheap (a Honda dealer here in CA) sells the same thing for $240.
Still, $100 a set is exceptional. If they fit, they're sold!
Correct. I was saying msrp. Most dealers won't move off that price besides a few online retailers like college hills honda.
Oh, so A.G.'s lights are nothing after-market... they're just OEM from a sedan? If that's the case, how much to replace those projectors?!
Mini h1 projectors are $135 from theretrofitsource. That would be the easiest retrofit to do.
Unreal. Thanks so much.
Was wondering... maybe i should return the favor and sell my own headlights... they're beat up but still functional. $25.00 would probably make somebody very happy. And I can buy the adjustment screw thing myself from TRS.
Status
