DIY Retrofitting Electric Lumbar Adj. Leather Seats - European Model Civic.
Raizenkohakus
New Member
2
2
This is a DIY tutorial on how to build the seat heating harness for retrofitting OEM Leather Seats with lumbar adjustment.
This tutorial does not contain information on how to remove the seats or the centre console, there are plently on 9thcivic already
and quite frankly, it's 4 bolts and a few connectors, pretty straightforward.
I have not removed the centre console to install the harness as it takes too much time, I have inserted my harness through the radio hole in the dashboard
then pulled the wires down the centre console and then under the seat. It is NOT the way to do it
DISCLAIMER:
This is a complex DIY tutorial involving:
- interaction with very sensitive Supplementary Restraint System Components (Seat Airbags);
Careless interaction might result in your airbag being deployed.
Always disconnect battery 3-10minutes before attempting to disconnect the SRS connectors.
- You need at least basic knowledge of electrotechnics to understand what you're building here.
Google: Ohm's Law, Voltage Drop, Resistivity. -
These 3 basic pieces of information will help you understand why you need 1.5mm CSA / 16AWG wires from the 15A fuse to the seat relays.
Short answer: even if Honda can get away with 1.0mm CSA or even 0.75mm CSA,
you absolutely don't want to risk melting the wire and maybe creating a spark under your dash/seats so THICK is BETTER for PWR and GND.
- You need to have a rough idea on how to solder wires.
Following this DIY is your choice and yours only, you are the sole responsible should this DIY set your car on fire or worse.
By moving forward with the DIY you understand that no one else besides you is responsible should things go wrong.
TOOLS NEEDED:
1/4in drive ratchet
10mm socket
14mm socket
Phillips head screw driver
Flat head screw driver
Digital Multimeter
PARTS NEEDED:
-OEM Switches - This I could only find with the entire MK9 Heater Display
(I paid 40£ for mine)
-5x 1.5mm CSA / 16AWG wires 2m length each
(I have bought them from here)
-6x 0.35mm wires 2m length each
-4x eBay inline connectors
(Tyco Waterproof) (I have bought them from here)
-4x Piggyback Low-Profile Mini Fuse Tap
- TESA Wiring loom tape
(I have bought it from here)
- Eyelets 8mm,10mm and 13mm - see what works for you, I used 13mm for the seat bolt gnd and 8 or 10mm for the radio chassis bolt gnd.
- Electrical tape (found everywhere)
- Thermal contracting tube - nice to have.
- Mini low profile fuses. (Halfords?)
- Split Corrugated Tube 20mm internal diameter (haven't used yet, waiting to arrive)
THE CIRCUIT DIAGRAMS:
- I have provided both the OEM circuit diagrams and my own circuit diagrams which I have drawn to help me create the harness.
I have NOT followed the inline pin cavities nor the colours found in the circuit diagrams (OEM and Mine)
so please DO NOT associate the colours of the wires in the pictures with the ones in the diagrams, I had a very limited choice of colours.
- My circuit diagrams and the tutorial itself was created around the fact that I did not have the OEM plug-in connectors
so I had to re-solder new connectors on seats and solder the wiring straight to the switches.
(90% of the cases, you won't get the plug in connectors with the switches).
WARNING! - Some model years have the control wires for Relay LOW and Relay HIGH swapped between Passenger and Driver switch!
Make sure you check with a multimeter the Relay Low and Relay High switch pins before soldering anything!!!
My 2013 Honda did NOT have Low and High pins swapped on the switches. Pin 1 was low and pin 4 was High for both.
GROUNDING POINTS:
AGAIN, I DON'T RECOMMEND doing it the way I did!
- I've connected the 1.5mm CSA Ground for the seat heaters to one of the seat bolts after I've sanded the paint away.
Not the best engineering solution, Ideally if you can, bolt it to a ground in the centre console or maybe the seatbelt bolt this is hidden out of your hand's and foot's reach.
Or maybe one of the bots in the rear of the seat, I have used the ones in front but the wire is now visible and I'm looking to change that.
-The ground wire for the switches, you can use one of the 2 bolts which holds the radio in, that's a pretty good grounding point.
INSULATION:
TAKE EXTRA MEASURES TO INSULATE YOUR HARNESS!!!
Use the tesa tape above only after you've finished insulating the copper.
MAKE SURE YOU SOLDERED THE WIRES PROPERLY AND THEY ARE WELL BONDED TOGETHER!
(IMPERFECT SOLDERS CAUSES SPARKS, SPARKS CAUSE FIRES)
For example if you spliced 2 wires, you need to use electrical tape (a lot) to seal the splice before considering taping the harness
After you've finished with the electrical taping, then with the cotton taping you can use a split corrugated tube (20mm internal diameter minimum)
(electric sparks from an imperfect soldering + cotton tape is a fire hazard and you'll most likely set your car on fire if you mess this up)
Best of luck.
¬Ray.
Pictures list:
View: https://drive.google.com/open?id=1LT0LiBcsw_3MF9-LMhCY6y1gKhdGb2y6
  • Circuit Diagram - Seat Heating.pdf
  • Lumbar-Circuit-Diagram.pdf
  • Honda-Civic-9th-Seat-Heater.pdf
  • Honda Civic MK9 Heated Seats Retrofit.pdf
Thanks for the diy. I see you’re from the UK. Your civic is different from the one found in Canada/US, which is where most users are from on this site. I just wanted to make a note of that so users weren’t confused when looking at your post.
Many thanks for it, I've had a look at the heating switches in the Civic for the Canada/US market and it seems they are identical, I couldn't find one with the buttons from the seats but they should be fairly similar to the EU market in terms of cavity pinouts.
The Honda diagrams should match or at least give a pretty good insight.
However I recommend that always double check a diagram pinout using a multimeter (continuity test).
That's how I've done it at first, I didn't trust the diagram and I've only used it as a means of double checking.
I've tested the continuity of the switches to find out which is relay LOW, which is HIGH and which are the GNDs.
To find out the GND and PWR for the Backlight normally you can use a 12V power supply.
Make a note/diagram of your findings and then compare them to the honda diagrams, if they match, even better. (THE DIAGRAM DID NOT MATCH MY SWITCHES FOR RELAY LOW AND HIGH!)
Same goes for the seat buttons, you can test the functions of the lumbar adjustment and the heaters using continuity tests and a 12V power source.
(I use an ATX power supply from an old computer because it ca easily supply over 15A on the 12V rail).
First you need to power the relay to switch the seat heating on then you can do a continuity test on the thick wires to find out which is GND and which is PWR.
(on EU seats the wires are LT GRN for GND and RED for PWR, should be the same for all markets)
we only had the EX-L trim that had leather/power seats and they didn't have lumbar adjustments. It just had basic up/down tilt functionality. Our SI sport model trim doesn't even have leather or power.
