What is the normal range temperature coolant?
pyDante
New Member
1
0
I got an OBDII scanner I was reading about 80 - 95 C° (188.6 - 194 F) on highway without AC and no traffic, I read 97 -101 c° (206 - 213 F) with traffic, I don't know if that ranges are good or bad when temperature is 100 or 101C° (212-213 F) the fans are activated
What is your opinion? Is normal temperature range?
Honda civic 2013
Coolant Prestone 50/50
77,698 miles.
Normal
Hi there, that seems a bit high from my experience. I run between 88 and 91 in summer with or without AC. Have you replaced your thermostat? Mine is all factory including antifreeze(changed once). But I'm at over 220,000km
