Nix
Jötunn Moderator
Disclaimer: I am not into the flushness/wide wheel thing. I don't hate but it's not my thing. This is the wifes DD so she wanted it to look a particular way. I was all about 18x8 +40.....
Ok so I got the new wheels and tires mounted on my wifes sedan this morning. They look awesome. Exactly the look she wants.... but the rub. (I was against the size due to the potential for problems.)
2009 LX sedan
Stock height! Upcoming drop is the 0.75" HFP.
18x8.75 +35
225/40/18 tire: Falken 912
Alignment just done: no more than -0.5 camber anywhere.
I consulted tons of threads and fitment charts. I even messaged some people who own the same wheel and they said they were lowered with no rub.
I have rubbing in the rear only. Fronts seem fine so far. I took some pics so I need a quick consult with some of you wide wheel guys as to the best fix.
Side shot: Yes they are dirty and have the mold release stuff and the mounting goop on them. It's rainy so Ill be cleaning them as soon as possible. (They have been sealed already, should clean up quick.)
Front: Poke a little? Camber bolts on the way. Will -1.25 or so pull it in enough? Currently no rub in the front.
The problem area: The rears.
Here's where I need some help. sk8nava , AlienPrime. Sk8 I hope you can help me the most since you used to have a very similar car.
This shot shows the "rub" line on the sidewall of the tire. Right above where it says ZIEX
I took a shot looking up at the fender. Is this white line where the tire is hitting? I'm going to try and clean it off and then drive and see if it reappears indicating a contact zone.
So my question is: Should I roll? Shave? Just run a camber kit? Let me know guys. For the next couple days Ill be driving very carefully. I only rubbed on a large dip pulling into the parking lot so far. No issues highway and otherwise flat driving. Thanks!
2009 LX sedan
18x8.75 +35
