I sort of explained this in a different thread but this may get more attention from people looking for answers.
The full tech article:
http://asia.vtec.net/Engines/RiVTEC/index.html
In short the iVTEC on the r18 is for fuel economy not power. Over 3k rpm and you are out of "VTEC" range and into a normal cam profile. It makes the car feel like it has more power but it is not the same as the VTEC on the Si. There is only one cam so having it operate in two different ways is pretty impressive.
Spirited driving means you are never in VTEC with an r18. It's very different since VTEC on most Hondas ALWAYS comes "on" at a set RPM. With iVTEC throttle/driving conditions have to be in set parameters for the ECU to activate VTEC mode - for fuel economy.
Under normal driving conditions, the R18A runs on its normal set of cam-lobes which in a completely reversed role, Honda calls the 'hot-cams'. So VTEC-off on the R18A means it can be considered to be running high cams. When the right conditions are acheived for fuel economy, VTEC engages the 2nd set, the 'low' or 'economy' cams. Thus VTEC-on on the R18A means it is running low cams. More importantly is VTEC engages the low-cams only if the right conditions for fuel economy are acheived. If they are never acheived, like when we are driving aggressively for the whole trip for e.g., VTEC will never open on the R18A.
