Jake Trashansky
I'm on the hunt for coilovers for my '13 si coupe. I'm leaning towards D2's. OPINIONS??
How much do you want to spend?
Indeed.... what is your budget?
The redshift coilover/ground control kit is real nice. I also like the KW Variants which should be out soon.
Right around $1000 you've got a lot of options. People seem pretty happy with the D2 setup. I'd also recommend you check out the K-Sports. They have a lot of nice adjustability. If you're budget is flexible in the $1000 range I think the redshift coils are the best performance option.
Redshift coilovers:
http://www.redshiftmotorsports.com/RedShift2012CivicSuspPackages.htm
Scroll down the page to the coilovers section and check out the Series 3 Koni based setup. It's a little over 1k but with the refundable cores option you're looking at $1200 range. Also totally custom spring rates available.
Swift Linear Race Springs Standard
Standard Spring Rates:
Comfort Street 350F/440R
Street/Track 440F/525R
AutoX/Track 440F/650R
would you recommend it over the bc? asking your personal opinionRedshift uses koni shocks & a whole list of lowering spring options that you pick.
