Hey guys,
I know there is a separate section for intake discussion. However, I'm more concerned with the technical aspect of adding a intake to our cars than reviews on brands.
I've been looking into picking up a intake for my 2012 Civic SI. After looking deeper and reading about after market intakes causing check engine lights and misfire problems, I'm starting to second guess the upgrade, especially after seeing/hearing videos of valves ticking hard such as this:
View: http://youtu.be/pmaNk7Z2LTk
What causes the K24 to not accept cold air intakes well? Does it depend on whether of not the air flow sensor is moved or replaced? Would a mixture adaptation or ECU flash for sure fix the problems these intakes cause or are these cases just isolated to certain cars... There doesn't seem to be a definite answer anywhere on here.
