marinse
- 52
Car does look good man. Whats the regret on the fender pull? They don't look too bad from the pics. I know there are small fender flares you could get. Maybe a small bolt on flare to cover the OEM ones if the lip/edge is damaged. Might be cheaper. The 8th gen mugen RR flares were very slight. It might hide the edge enough for you and flow with the HFP kit. They aren't overbearing like the rocket bunny style ones that are out there. Or run front flares on the F & R. Just thinking out loud I guess...
Its pretty bad, you can't tell from the pictures I took. I pulled them out enough to cause the quarter panel to buckle right above the fender lip on both side.
The main reason I'd like to fix it is because it annoys me personally, plus it would reduce resale value down the road.
