Kylesn52
Member
Curious if anyone knows if the seats from an ex-l (leather) will fit in an ex. I cant keep my cloth seats clean and I hate seat covers. I get that the heated function likely won't work but I just want leather.
I think a couple people have done it but had to go to the dealer to have the SRS airbag system reset. Other than that it should all bolt right up and the airbag plugs should all connect without issue. If you want to have the heated seats functional I think you would only need to buy the on/off switch assembly and connect them to power.
If you do this swap or anything that involves messing with the SRS system disconnect both terminals of your battery for at least 15 to 20 minutes before you start working.
