Tony-si
I'm used to doing 3 months or 3k miles on a normal car but some one said the civic can go a little longer? Is this true or for only if you use synthetic?
oddly i paid $39 at the dealer last time.I would just follow the maintenance minder. Probably about 6-7k miles. Some prefer to do it a little sooner. Your call of you want to spend the extra cash to do it more often.
when i did the iol change the car computer was still showing it at a high life. but i wanted clean oil since the dealer did it for certification.Oil is the lifeblood of an engine... i'm for doing more often. But seriously, even non-synthetic oils are pretty stout these days; 5,000 isn't normally a problem. Just don't forget that oil degenerates even sitting around. So I follow the "3 months" or 3,000 - 5,000 mile routine depending on the type of miles. On a cross-country trip I wouldn't worry about a good synthetic for at least 10,000 miles. Around town driving every day? 3 months.
If you plan on keeping the car a long, long time, I'd buy that new Pennzoil Platinum -- for the money it's best stuff out there. Personally I prefer the "Ultra" Platinum version (for extreme conditions) but WalMart only carries the regular Platinum... fortunately it's dirt cheap, like $25.00 for the 5 quart container. It's so much better than Mobile 1.
Bottom line: Both Pennzoil products are fantastic Group IV PAO's (Polyalphaolephin) whereas M1 is only a Group III hydrocrack ... not nearly as good.
Of course the most scientific and reliable way to tell how often to change oil is to send a sample of used oil to Blackstone Labs after 5,000 miles. And pay the extra $10 (just once) for the TBN (Total Base Number) test that tells you how much life is left in the oil. The lab results also provide baseline engine information (the presence of wear metals like iron) that later can be used to determine when engine failure is more likely.
I too usually go by the maintenance minder. I have noticed that once I reach say 50% oil life, I get much less time before I change it. IE, it takes the cars say 4500 miles to reach 50%, but maybe only an additional 2000 miles to the 10-15% "oil change needed". Not that this is a bad thing, mind you, just an observation.
To those that are changing their transmission fluid, are you doing that as recommended by the maintenance minder or individually? The last time I changed my oil (50k miles or so) the maintenance minder told me to do transmission fluid as well.
would that be something the dealer would have done when they certify the car? i got it almost a year ago with 24 miles.Every other oil change is just a personal preference. Most dudes I know don't go past 30k without doing a tranny fluid change in manual car.
I wont have to worry about the trans as i purchased it from the honda dealer certified so i believe they did that. i have the copy of what was checked and done..I do oil every 5k. Full synthetic. Probably don't need to that often but Texas is hot and past that I feel like she doesn't run as smooth. Transmission every 20-30k or so.
Going to stir up the pot here for saying this, but I only change my oil once a year, however many miles I go. After dumping the factory fill per maintenance minder at 8k, started using Mobil1 AFE or EP. I just go 1yr or however many miles the oil's rating is. Using the Extended performance so I could go 15k if I wanted. Mostly I average 7-8k a year though.
________________I've always done 5k, 6 months, or 20% on the maintenance minder, whichever comes first on all my vehicles with fully synthetic.
