- 55,567
- 23,829
So I hooked the yellow (actually green in my case) wire from my RCA cable to Pin #19, and the red and black wires inside the RCA cable are hooked to nothing. When I put car in reverse, it switches to reverse camera, but the video feed looks like crap. Don’t know if it’s because the camera is garbage, or if my red and black wires within the RCA cable need to be hooked to something.
I took a picture of my video feed, and interestingly, my phone makes the video feed look way better than it does in real life. In reality, the feed is real dark, and so far my backup camera is unusable due to the poor quality feed.
so I went back and started to read the first few pages of the thread, because it's been ages since I've looked at it -
It' not thouroughly explained as to what I do with the stripped RCA cable. I have 3 wires sticking out.. IDK what to connect them to.
During the strip/prep part, its says that the third red wire is ignored, one is ground, the other is vid. Those two will connect to the wires running to the front as video feed. And of course the RCA male end is connected to the yellow RCA female end that is coming out of the camera. If you look at the diagram, it reassures you to do so as well.
@Pauly99to17 did this diy and was online yesterday. Maybe he can also chime in on the last few posts in the thread regarding the rca wiring / extra 22 gauge wire in the "needed items".
