TuckerSI
Active Member
Hey guys, so im thinking about trading a guy my vsxx's for his TE's and his offset is 18x9 +45 all around. My question is will this fit without any spacers or anything? Thanks guys!
I dont know how close I am actually. Willtheyfit.com says im 22.4MM's closer to the suspension strut.
pic? Suspension setup?I'm running 17x9 +45 on my Si and it clears the strut. I feel like the back just needs a small spacer for it to look right.
I'm going to be lowered on Godspeed mono-max's, just waiting for them to come out in about a month or so. And I think the tired he has on right now are 215/40/18I have 17x9+42 and they fit with stock tires and H&R springs.
Are you lowered? What tire size are you planning on running? Do you want to stretch your tires?
hold on a sec, theres a wheel fitment guide on this site. Ill find it for you
Man, i forgot to take a pic before work =/I remember people running 17x9 +45 hitting the suspension on the 8th gens. The 9ths seem to have more room to the fender but I don't know about strut clearance. Tire size may play a huge role.
At least with the +45 you can safely run a 3mm spacer on the stock struts and push the wheel out to a +42.
@Dutchmaster - What size tire are you running on your wheels? If the +45 hits and you run a spacer, you might be clear with the same tires as Dutch.
+40 should fit alittle better than +45. It will be 5mm further away from the strut.so the guy just bailed -_-! Lookin at another set of TE's but their +40 and not +45. Is it a big difference?
springs/coilovers/stock suspension?... how low are you? The lower you go, the more it mattersI have a coupe ...18x9.5 +40 or +38!??and whats the meatiness tire i can go, without camber??
