Hmmmm. Time for me to review your pictures again. Sounds like good advice. Thanks.
bigbossin I've got the loctite ready!
No problem.
But really, long story short, just take it out...
yes very true honda always has to go above and beyondI was quite surprised at how easily the cable laid on the floor next to the side of the console without moving. It is not like there was a bunch of slack or a real need to have it connected to the shifter mechanism.
i did mine with it in, tell Arm0ged0n sayd i really needed to cut the piece off! so i had double the work of taking it all apartNo problem.
I love it and wish I would have done it on my last car. Even though the claim is that it saves 20-25% movement, it seems like a whole lot more. The base bushings have virtually eliminated the play at the end of each shift. It is SOLID.
That being said, due to the nature of the work to put in a short shift adapter, I HIGHLY recommend doing the base bushing at the same time.
I have yet to do the cable bushings. I am debating between the CorSport ($33) and Hybrid Racing ($70) one's.
I am curious about this claim from Hybrid Racing:
Input would be appreciated from everyone.
Very nice. You inspired me to do this and I ordered the parts.
That is good to hear. Sadly, $70 for the Hybrid Racing one's is a bit pricey right now. They are definitely near the top of list, though.I did a bunch of research and found that everyone that said CorSport's wouldn't work were 2nd hand (none experienced it themselves). Personally I went with the Hybrid Racing. They are working wonderfully for me.
If you do this, you should still take the left shift cable off just in case something weird happens when you strike the wrench. This would include taking the center brace out in order to pull the cable away from the mechanism and give clearance. I wouldn't simply take the cotter pin out as there is not much play and the moving parts could still hit the cable causing damage.
Do you have a picture of how much plastic you cut off?Did you guys notice that even after it is trimmed, when the car is put into reverse the shifter cable touches the shifter (not much at all, but just curious)? It didn't seem to affect shifting into reverse at all, but just was curious.
Just finished up putting it all together (short shifter and base bushings). Was made much easier because of this DIY.
To get the blue end cap off I used a different method. Stick a small flat blade screwdriver into the bottom (smaller opening) then rotate the blue part until it is all the way tilted, then use the screw driver to pop it off. No damage to the blue cap (thank goodness). Also just used a piece of left over wood and my hands to pop it onto the CT short shifter.
Also, I nearly lost a bolt under the carpet...few moments of panic there.
I did not notice any clearance issues on mine.
Just a word of warning to those thinking about prying the cap off with this method. You run the risk of distorting/stretching the blue cap out which can increase the chance of it slipping off. When you take something off that is kept on by compression such as this, you want equal pressure all around when taking it off. Hence the recommendation of using an open end wrench.
NthTier I am not sure, but this my be why you were able to get it back on without using a vice or hammer.
great job on the diy - backed up the images
