I'm sure the polks weigh a lot more with the magnet differences.
I'd be surprised if they didn't? There are only a few examples of speakers I've ever seen which didn't use magnets. There are speakers called electrostatic speakers that don't use magnets... but they're like this -
http://www.martinlogan.com/learn/faq-electrostatic.php
Did you just replace the speakers, or did you do any other amp/ head unit work?When I was given back my stock speakers I laughed, but I have to say they didn't sound that bad, I just wanted more. My polks sound great.
Does this mean someone should focus on speakers with neodymium magnets for better sound?The stock speakers have a neodymium magnet, that's why it can be so small yet have high flux in the gap, it also uses a solid pole piece for higher BL than a vented pole, venting is done under the spider plateau. The Polk replacement uses a ferrite or 'mud' magnet, so it needs to be quite large in comparison.
A 4 inch x 3 inch solid neodymium magnet has enough force to lift one end of your civic off of the ground. 1200 pounds of pull:
http://www.ebay.ca/itm/Neodymium-Ma...942?pt=LH_DefaultDomain_0&hash=item53e735a83e
I am working on replacing the rear speakers and head unit. I was trying to find a suitable free air sub that would fit...but that does not seem to be possible.
I would concentrate on supplementing the low end, and leave the stock rear speakers in the deck.
