- 23,820
2012 Honda Civic Reviews
If you are thinking about purchasing a 2012 Honda Civic, this page provides a lot of resources for those who want to research the vehicle. I've compiled reviews, videos, comparisons, and magazine test data for all of the various civic models.
For those who are unaware, the 2012 civic is offered in a number of trims. There is a gas/electric hybrid version, a civic that runs off natural gas, and the most prevalent - two versions of the gasoline engine civic. The base engine that is found on the non-SI version, produces 28/39mpg respectively, while the SI engine produces 22/31mpg.
Civic HF, Sedan, Coupe and Natural Gas Specifications
2012 Civic SI Coupe Specs Link
http://9thcivic.com/forum/pages/2012-civic-si-specs/
2012 Civic SI Sedan Specs Link
http://9thcivic.com/forum/pages/2012-civic-si-sedan-specs/
2012 Civic Coupe Specs Link
http://9thcivic.com/forum/pages/2012-Civic-Coupe-Specs/
2012 Civic Sedan Specs Link
http://9thcivic.com/forum/pages/2012-honda-civic-sedan-specs/
2012 Civic Hybrid Specs Link
http://9thcivic.com/forum/pages/2012-civic-hybrid-sedan/.
2012 Civic Brochure
http://9thcivic.com/gallery/2012-Honda-Civic-Brochure
Click For Editorial Reviews of The 2012 Civic
Click For Video Comparisons & Video Reviews
2012 Honda Civic Image Galleries On 9thcivic
Main Gallery - http://9thcivic.com/gallery/
2012 civic sedan - http://9thcivic.com/gallery/2012-Civic-Sedan
2012 civic coupe - http://9thcivic.com/gallery/2012-Civic-Coupe
2012 Civic SI sedan interior - http://9thcivic.com/gallery/2012-Civic-Si-Sedan-Interior
2012 Civic SI sedan exterior - http://9thcivic.com/gallery/2012-Civic-Si-Sedan
2012 Civic SI coupe interior - http://9thcivic.com/gallery/2012-Civic-Si-Interior
2012 Civic SI coupe exterior - http://9thcivic.com/gallery/2012-Civic-SI-Coupe
Color Specific Examples of The 2012 Civic
(9thcivic users post vehicles they own or spot)
http://9thcivic.com/forum/forums/civic-color-specific-threads.33/
2012 Honda Civic- New Features Added
New Civic Features
HF Trim
This trim level will be equipped to achieve higher fuel economy, including lighter weight wheels, low rolling-resistance tires and aerodynamic enhancements. Other features are identical to the LX trim.
Electric Power Steering (EPS) on Every Model
EPS was previously on Si models only. For 2012, ALL Civic models are equipped with EPS.
Vehicle Stability Assist (VSA) on Every Model
Vehicle stability assist with built-in yaw sensor is on every 2012 Civic model.
One-motion Interior Door Handle
Both front interior door handles will unlock and open the door with one pull of the handle. The 2012 Civic is the first Honda model with this feature. This convenience requires that front seat passengers never pull a front door handle while the vehicle is in motion.
New Civic Technologies
i-MID (all but DX model)
The intelligent Multi-Information, Display will page through odometer/trip, clock, audio, and trip computer information as well as warning messages. The Si includes a power output meter. The Hybrid includes displays for energy flow and Eco guide. Door locking, trip computer and lighting can be customized, including importing of wallpaper images for the i-MID.
New Hybrid Battery Pack
The 2012 Civic Hybrid has a new lithium-ion battery pack. It will not fully charge until the vehicle is driven.
ECON Mode (all but Si)
The ECON mode helps maximize fuel efficiency by adjusting the performance of the engine, transmission, heating and cooling system, and cruise control. This mode is activated with the green ECON button. An indicator will appear on the instrument panel while it is activated.
NOTE: When using the cruise control in ECON mode, it may take longer to accelerate to maintain set speed.
Driver Distraction
The navigation system includes new restrictions on manual operations while the vehicle is in motion. While driving, some options are shaded on the menus and must be accessed using voice commands.
Navi Turn-by-Turn Display
The navigation system’s turn-by-turn information displays on the i-MID as well as the main navigation screen. The 2012 Civic is the first Honda model with this feature.
New Navi System
The 2012 Civic navigation system uses a flash memory drive instead of a DVD or HDD. If a navi control unit must be replaced, the SD module must be transferred to the new control unit. System updates will be available for purchase on a flash drive, which is plugged into a USB update port behind the glovebox and uploaded to the Navi system.
FM Traffic
Navigation-equipped Civic models are capable of receiving FM Traffic data. With the information Broadcast on certain FM radio band in available areas, this free service requires no subscription.
Audio Anti-Theft
The anti-theft code is automatically checked between the ECM/PCM and the audio unit; there is no longer a need for anti-theft code cards. However two anti-theft code labels are included. After you unlock the audio unit, attach one of the anti-theft code labels to the PDI repair order. The second label should be given to the customer for safe keeping, rather than left in the vehicle.
NOTE: If the audio unit loses power, turn the ignition switch to ON (II). Press the audio power button once. Press and hold the audio power button again until you hear a beep and see the audio frequency on screen. The VIN anti-theft process is then complete.
Radio Preset Memory
If the battery is disconnected, the radio will remember the customer’s station presets.
Battery 12-volt Energy Management
Battery current amount is monitored by a battery sensor. The PCM varies the ACG voltage between 12.5 to 14.5V based on data received from the battery sensor. This ensures optimal battery state-of-charge.
Cruise Control System
Cruise control will not cancel until the clutch pedal (MT transmission-equipped vehicles) has been depressed for 5 seconds or more.[/quote]
i-MID Demonstration
.Help spread the word about 9thcivic as the leading 9th generation Honda Civic Forum by liking us on facebook, following 9thcivic on twitter, and Registering to the site if you're a guest!
GUESTS - 9thcivic is Free to use, and you'll gain access to additional site features and options by signing up. You don't even need to register for an account if you already have a facebook login..M
- 140 horsepower, 1.8-liter i-VTEC™ 4-cylinder engine
- 5-speed automatic transmission
- ECO Assist technology
- EPA-estimated Civic HF highway fuel economy: 41 mpg
- EPA-estimated Civic Sedan and Civic Coupe highway fuel economy: 39 mpg
- 110 horsepower, 1.5-liter i-VTEC™ 4-cylinder engine (combined gasoline + electric)
- Continuously Variable Transmission (CVT)
- Lithium-ion battery
- EPA-estimated Civic Hybrid city/highway combined fuel economy: 45 mpg
- 200 horsepower and 170 lb-ft, 2.4-liter i-VTEC™ 4-cylinder engine
- 6-speed manual transmission
- EPA-estimated Civic Si highway fuel economy: 31 mpg
2012 Civic Brochure
New Civic Features
HF Trim
Driver Distraction
New Navi System
FM Traffic
Audio Anti-Theft
Radio Preset Memory
i-MID Demonstration
