2013 wheel lights
Discussion in '9th Generation Civic General Discussion' started by Tony-si, Aug 11, 2017.
  1. Tony-si
    Tony-si Active Member
    112
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    Is it me or are they illuminations in the wheel not very bright?
  2. webby
    • 2017 Toys For Tots
    webby Administrator
    46,944
    Like the volume and whatnot? Yours look like this? Are you adjusting the dash brightness?
  3. Tony-si
    112
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    Yeah the dash is much brighter then the wheel it still seems dim no matter what i set..
  4. webby
    webby Administrator
    46,944
    I mean you can tell from the pic above it's nowhere near as bright as the hvac/dash buttons.
  5. Tony-si
    112
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    it looks brighter then mine
  6. WrongWayWade
    WrongWayWade Well-Known Member
    6
    The factory footwell LED lights are screwy because they are covered with a translucent plastic cover. I had to remove them and drill a hole in these covers to let the light out.
  7. Tony-si
    112
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    i mean illumination from the wheel
  8. WrongWayWade
    6
    I got confused when I saw webby's picture. The wheel controls back-lights do go up and down with the dimmer. They aren't that bright but that is by design.
  9. Tony-si
    112
    North Hollywood, Ca
    Vehicle Model:
    Civic SI
    Body Style:
    coupe
    ahhhh ok that makes sense. i would like to make it brighter later on.
Share This Page
