Robert Ian
New Member
My 2015 Civic window wash is not pumping. Is the pump audible under some conditions to verify that the interior lever switch is working? Where is the pump located? Is access to the pump easy?
first thing - is there fluid in the reservoir? Your profile says Daytona, so I'm guessing you're not in a cold area currently? Lines can freeze, so that's why I was asking about your location.
The pump is located with the washer fluid bottle behind the bumper. You can't see it without taking the bumper off as far as I know.My 2015 Civic window wash is not pumping. Is the pump audible under some conditions to verify that the interior lever switch is working? Where is the pump located? Is access to the pump easy?
