9th Gen Civic Si Fully Built High Compression k24z7 Head Power?
Discussion in 'Bolt-Ons And All Motor' started by Garrett Allison, Jul 17, 2019.
  1. Garrett Allison
    Garrett Allison Member
    17
    Hey, I have a 2013 Honda Civic Si Sedan and I’m full bolt ons making 220wheel HP and 187tq and I’m getting my RBC ported and I’m about to have a fully build 4PistonRacing k24 short block 88mm bore 12.5:1 and ported Rsx type s oil pump and I have my head in the shop getting skunk2 valve springs installed along with a 7angle valve job and a full head port and polish and i plan on revving it out to 8500rpm and I was wondering does anyone here know the possible or estimated power output after doing all this work? I’m going to be doing a 93 tune and a E85 Tune
    webby likes this.
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    50,570
    You’re going into uncharted territory from what I’ve seen done here naturally aspirated. You have to post up some dyno numbers when you get it done!
    Garrett Allison likes this.
  3. Garrett Allison
    17
    Okay I will!!!
  4. Garrett Allison
    17
    Yeah the goal is to do things nobody else has done in here ever before! Cause as far as I know nobody else has done what I’m doing N/A
  5. Garrett Allison
    17
    My Mods are:
    4PistonRacing K24 88MM Bore Short Block
    Wiesco 88MM 12.5:1 Forged Pistons
    Saenz S-Series Forged Rods
    RSX-Type S Ported Oil Pump
    ARP Head Studs
    Cometic Head Gasket
    K-tuned Timing Chain Tensioner
    K24z7 Full Port and Polished Head
    PRL Cold Air Intake
    SiriMoto Throttle Body Spacer
    RBC Ported Intake Manifold
    K-Tuned Coolant Block Off Plate
    Throttle Body Coolant Bypass
    Invidia N1 Full Cat-Back Exhaust
    Skunk 2 Alpha Series Header
    Koyo Racing Radiator
    Mishimoto Racing Thermostat
    Hasport Transmission Mount 95A
    Hasport Rear Torque Mount Solid
    Hasport Upper Torque Mount 95A
    NGK Laser Iridium Spark Plugs
    DeatschWerks 750cc Injectors
    Hondata Flashpro
    Hondata Intake Manifold Thermal Gasket
    Sirimoto Throttle Body Thermal Gasket
    DeatschWerks DW65C Fuel Pump
    ron v, mySIck, sunofwolf and 2 others like this.
  6. Garrett Allison
    17
    Transmission/Shifter:
    BC Racing-Spec Short Throw Shifter
    SiriMoto Shifter Base Bushing
    Fully Built Transmission
    MFactory LSD W/Stage 1 RacePack Upgrade
    Action Clutch Stage 2.5 w/Ultra Light Flywheel
    K-Tuned Clutch Master Cylinder
    K-Tuned Clutch Slave Cylinder
    K-Tuned Stainless Steel Braided Clutch Line
    Suspension/Handling:
    SiriMoto Phase 2 Upper Front Strut Bar
    SiriMoto Phase 2 Lower Front Tie Bar
    SiriMoto Phase 2 Lower Rear Tie Bar
    Megan Racing Street Advanced Coilovers
    Eibach 24MM Front Sway Bar
    Eibach 19MM Rear Sway Bar
    Godspeed Rear Camber Kit
    300MM Drilled/Slotted Rotors
    Federal 595RS-RR 215/45 Rear
    Federal 595RS-RR 235/40 Front
  7. Garrett Allison
    17
    Exterior/Appearance:
    ESR SR01 Black Chrome Wheels
    Mugen Carbon Fiber Wing
    Pro Design Alpha Style Front Lip
    Pro Design Roof Spoiler
    Pro Design Sunroof Visor
    JDM Red Honda Badges
    Seibon Carbon Fiber Hood
    SpecDTuning LED Dual Halo Headlights
    Tinted License Plate Cover and Frame
    Tinted Rear Tail Lights
    sunofwolf and bootyluvr like this.
  8. webby
    webby Administrator
    50,570
    quite the mod list. How's the vibration with mounts that stiff?
  9. Garrett Allison
    17
    H
    Honestly, not bad or maybe I’ve just got used to it lol
  10. Garrett Allison
    17
    Funny thing is it’s my daily driver
  11. webby
    webby Administrator
    50,570
    I know some that have 85a complained about vibrations, so that's why I asked
  12. Garrett Allison
    17
    Yeah I was reading before I got them and everyone says it was awful but I have 95a and my rear torque mount doesn’t have a bushing it’s literally metal on metal and you can only really feel a good vibration when you turn the A/C on other than that it’s not bad at all
  13. Garrett Allison
    17
    At the drag strip I couldn’t find a way to eliminate wheel hop and it was so bad I broke my stock mounts so bad the engine was touching the firewall and an axle snapped. I tried solid mounts and traction bar and it didn’t work my next mod is gonna be solid control arm bushings in the front and pray it will nearly eliminate it or get rid of it all together
  14. webby
    webby Administrator
    50,570
    was that on slicks/drag radials?
  15. Garrett Allison
    17
    On street radials federal 595 rs-rr 235/40
  16. Garrett Allison
    17
    Yeah even with street radials still wheel hop
Share This Page
