AlienPrime
What does it really do. From the looks of things i think it's like a Relay or GFCI type module.. here's what manufacturer says about it...
any idea exactly how this works or what it's doing?
- C-west racing voltage stabillizer
- High quality Red anodized finish with water resistant coating
- Keeps consistent voltage to maximise performance
- Will dramatically improve performance and aperance
- Easy to install will not require module or trigger check engine light
- Will work with all 12V battery system's not compatible with 6V systems
- 4.25"x2.5" cody can be intalled anywhere
- Light weight cnc machined aluminum with biult in heat sinks
- Will improve throttle response
- Improves voltage stability and power supply
- 0.5ma draw so it will not drain the battery
- Will gain minimum 3HP and as much as 15HP
