Ya, it's a funny thing. I love blue so much so I changed the display to have only blue, but the display became visually less interesting. Switched it back. Prefer the gimmicky disco lights.![]()
i think there's a DIY to making them brighter by drilling on to the lense that covers the bulb on the red ambient light they used a blue lense and it covers the light significantly. Check it out I'll try to post the linkBy the way... @Pauly99to17 what footwell lights did you use? I have the OEM red ones but dam you cant even see them! I assume I just need to upgrade the lights, as the wiring should be fine?
here's that DIY http://9thcivic.com/forum/threads/2012-civic-si-ambient-lights-red-si.4288/By the way... @Pauly99to17 what footwell lights did you use? I have the OEM red ones but dam you cant even see them! I assume I just need to upgrade the lights, as the wiring should be fine?
Love the idea. That would be perfect. Anyone ever opened up the speedometer before? I wouldn't want to be the first to try to do it.Retrofit it to change from dark blue to light blue! Eliminate that intrusive and unwanted green from the inside of your car.
Love the idea. That would be perfect. Anyone ever opened up the speedometer before? I wouldn't want to be the first to try to do it.![]()
You could just cut that weak asss OEM lights off and add a small LED strip.By the way... @Pauly99to17 what footwell lights did you use? I have the OEM red ones but dam you cant even see them! I assume I just need to upgrade the lights, as the wiring should be fine?
