Cruise Control
Discussion in 'Mechanical Problems & Technical Chat' started by Ethan Hall, Jul 25, 2017.
  1. Ethan Hall
    Ethan Hall New Member
    1
    My main cruise control light will come on but when I try to set the cruise nothing happens. Does anyone know what the problem might be and how to fix it?
  2. Nix
    Nix J├Âtunn Moderator
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    Year/trim? If you turn on the main cruise mode and then hit "set" it can take a few seconds to engage.
    EX: if you want the cruise at 65mph, turn on cruise, drive up to 65 and hit set, accelerate up to say 68 and then ease off the gas slowly. The car should catch and stay at 65. It can take a few seconds for the system to engage and hold, hence the pass, set, and ease off.
    Someone else correct me if I'm wrong.
  3. Enigma346
    Enigma346 Well-Known Member
    225
    Virginia Beach, VA
    Vehicle Model:
    Body Style:
    Also, if your foot is even barely touching the clutch pedal, it will not engage. Mine was touching it and I didn't know it and got new wondering why mine wouldn't engage at that time.
  4. webby
    • 2018 Toys For Tots
    webby Administrator
    49,523
    After turning cruise on you have to hit the "set" button to get it to the speed you want. I believe set is on the bottom of the circle (right side of steering wheel).
  5. aZnCdn
    aZnCdn Well-Known Member
    20
    Did you ever find a fix for this? Mine stopped working, when I set the speed the car would stutter a bit then the cruise would turn off. Seems to me it might be a relay fuse given the following characteristics: it was working, then kind of working, then not working.
Share This Page
