Wero15
Member
- 3
- 0
Any comments on this adapter? Does it works fine ? Do you need to change the bushings also as the other ss??
if you dont want to shave down your oem shifter, get the buddy club short shifter. it's plug and play
I don't know what they meant by shave down the plastic on your shifter, i have a '13 4 door si all i had to do was take off the little plastic thing that holds the bottom of the shorft throw adapter to the shift linkage cable and used the loctite they provided with the kit for the screws. i've had it for about 10k so far and its never came off or did anything sketchy. Matched with the hybrid shifter cable bushings, and base bushings it feels really good.
I didnt do that? had no need too..... dont see why you would?
