fg3_colton
The other day, I starting hearing a slight rubbing, almost grinding noise, coming from the passenger side rear wheel. I only heard this noise while I was braking and only from that one side. I was able to get it off the ground and noticed that the wheel in question no longer spins freely, it gets caught at one spot (Keep in mind, I had the parking brake fully disengaged). My first thought was a bad bearing, so I ran the basic tests, shook the hell out of the wheel in all directions but it was solid, no play at all. So I need yalls help, what could be causing this issue? I know little to nothing about the mechanics of a drum brake system, so my next best guess is this; The handbrake is only connected to that side, since I use it a lot, ive worn out the shoes and they need replacing. Hopefully you all can help me figure this out! When I get to my car tomorrow, ill record a video of the sound, and the wheel spinning.
Car in question: 2014, Civic LX Coupe. It is NOT equipped with rear disc brakes.
