barfyman362
New Member
- 9
- 0
Hey. I'm stuck on the final portion of my new build. I was going to reuse the old speaker wire for my front door speakers. So I ran new wire from my trunk amp to behind the head unit where I was going to solder them together. My harness adapter told me which ones they were so I soldered onto them but then I discovered the colours don't match for the front left door!?
Excuse my dirty fingers.
First pic is the wiring harness where you can see it has the brown/gray and yellow/gray for the front right door, but for the front left door it has the purple/gray but no red/gray. Where the hell is it!?
View: http://imgur.com/a/1VdB3
I tried to bypass this for an hour and a half by running new speaker wire into the door but the ******* rubber boot is so god damn tight, I even filled it with lube. I tried a coat-hanger, silicon clothesline, fishtank tube. Nothing can get through.
Edit: I should mention this is a 2012 EX sedan
