positive and negative battery cables
Discussion in 'Mechanical Problems & Technical Chat' started by mySIck, Jan 11, 2016.
  1. mySIck
    • 2019 Toys For Tots
    mySIck Well-Known Member
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I am looking into replacing my positive and negative battery cables. I am not getting a good connection with them now that I relocated my battery and it has caused it to strech the clamps from it being such I tight fit. And I have been having issues starting my car.
    Dose anyone know of the wire diagram and the part #s of the two for a 2013 SI
  2. webby
    webby Administrator
    50,570
    mySIck likes this.
  3. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Thanks I did not know about the discount.
    I did find that negative one on there website but the positive one I am having a hard time getting. I found a few for the 8th Gen but I don't know how much of a deference there is between the 2. I really want to see if I will have to replace my whole harness or if there is away to just replace the clamps.
  4. Nix
    Nix J├Âtunn Moderator
    10,765
    Lew-vul, KY
    Body Style:
    It's A Fast Pig!
    You can, if you're willing to cut and solder/butt connection some serious wire gauges, just extend your stock wires. You may want to look into welding supply websites for wire thick enough. Cutting the terminals and attaching new clamps is easy. However, getting 0/1/2 gauge wire is going to be a special order item. Same with the clamps. Measure them cause they aren't a standard size from my experience in doing battery related stuff. I could be wrong but its best to measure with these cars. They aren't GM/Ford products which is good and bad at the same time.
    CHH is awesome for stock parts and accessories though.
  5. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I would like to try and not cut it unless I really had to. I don't have any check engine light on so I assume that the battery sensor assembly is good. So I am planning on getting the cable assembly with the bolt and nut. But for the positive side I don't know if I am just looking it up wrong or what but no luck finding it. I am just going to try and call chh when I get a lunch break and find out if they can help me out.
  6. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
  7. Darkout
    • Supporting Member
    Darkout Supporting Member
    1,107
    Cocoa, FL
    Vehicle Model:
    Body Style:
    Yea more than likely your battery wires can only come as part of the engine wiring harness and that thing ain't cheap as it is usually the WHOLE harness. Normally several hundred's of dollars and not worth it unless you have rat damage or something bigger.
  8. 13blacksedan
    13blacksedan Well-Known Member
    266
    Would a big 3 kit work? They are usually long
  9. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I am hoping not. I just need to replace the post clamp. And I really don't want to cut it. It would seem like they would make it so that part can be replaced with out taking all of the engine wire harness out.
  10. webby
    webby Administrator
    50,570
  11. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    That is all i need but also with the skunk2 battery relocation it makes the cable tight and pulls on the positive and negative components. That is how they stretched out.
    But those look to be a thicker than the OEM ones. But if I where to buy them how do you take the cover apart for the positive cable clamp? I tried but did not want to brake it.
  12. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I am sure those are the two places to open up. But the the plastic is so soft and I don't want to brake it
  13. webby
    webby Administrator
    50,570
    Sorry I'd have to see it in person... I don't have a 9th to compare. You can't just flip the red cover up and get access to the cable from there?
  14. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
  15. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    That red part goes under the black part but see how much it bent
  16. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    20160113_221536.jpg that was the second picture my phone is acting up
  17. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    What is the easiest way to get that out
  18. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Or would I have to cut it
  19. webby
    webby Administrator
    50,570
    May be able to cut the clamp into numerous pieces with a dremel tool if you didn't want to cut the copper? Essentially you'd be making a bunch of cuts to the clamp to get it to release.
  20. mySIck
    1,746
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I ended up cutting it
    webby likes this.
Share This Page
