Redline on a auto r18
Tak
403
New York City
LX
Sedan (FB2)
Coming across this video , it seems he was able to floor it close to redline with D on his r18,auto or cvt?
View: https://m.youtube.com/watch?v=Srr9AqSoDC4
How did that happen on a r18? Rev limiter was disabled?
I did a few gunning with D from 0-60 only after stopping and exiting the toll. My civic dropped after 5000rpm (give or take)
Please post with positive comments.
Thanks
Hold the pedal all the way to the floor and don't let off. Mine gets up to almost 7k before it shifts. It needs to be in probably 1st or 2nd to really hold it all the way like that. Starting from a full stop and just mashing it should work. Once it's in 3rd it really doesn't have enough tq to hold to redline anymore and these cars try to shift as quickly as possible on you. Mine drops to 3rd at 18-19mph if I'm accelerating normally/slow. If you're rolling out from a toll booth doing 15mph the car is most likely already downshifted on you so far that you won't be able to redline it.
That's also a terrible video. He says "yeah feel the vtec" at around 1:10-1:15. Dude has no idea how his car works. He should really be saying "yeah, feel the vtec stop!" He's just coming to a stop and flooring it. 1st gear pulls to redline. 115hp/128tq. Whee?
If you have an auto, putting it in 3, 2, or 1 will lock the transmission out of any higher gear. If you put the car in 3 instead of D it will limit you to 1st, 2nd, and 3rd gear. Effectively you can then reach redline without the car shifting to a higher gear. I don't know about your particular year but if i put my car in 2 it stays in 2 and doesn't use 1st to get going. Starts are definitely a bit slower but you can hold that gear pretty much up to about 60mph.
Try driving around on some roads where the limit is 40-45 and put the car in "3" for a day and see how you like it. I do that at the Dragon and other spirited driving sessions. It will heat up your transmission a lot though holding higher RPMS. Very fun and you can use the little bit of power you have a lot easier. "2" is really a blast but the RPMS will be way up there and it's kinda noisy. try that also. I think you'll like it.
Do this if you want to run around in 2/3:
http://9thcivic.com/forum/threads/diy-at-transmission-cooler-dx-lx-ex-not-for-cvt.13700/
I just tried it. It didn't work. I did a complete stop at toll. As soon as the gate opened, I held the gas pedal, didn't let go while flooring it. It shifted as soon as it reached 5000 rpm +. Then it bounced off. I was on D. Econ was off. VSA was on.
Am I missing something?
Just viewed a 2012 lx auto get to like 6500 rpm in D on a 0-60 run in 1st gear. This may sound stupid, but you don't have a floormat or anything keeping your pedal from going all the way down right?
I do have floor mat but I don't think it's blocking the pedal. Fair point. I'm going to try it again tomorrow without the floor mat.
Thanks
