Dragos
I saw Seafoam mentioned more than once here so I got curious about it. I like the idea of it and I am thinking of using it.
A bit of research shows people use it in more than one way.
The simplest way is to add it in the tank and run the car. But I have also seen taking out main manifold vacuum lines putting in the engine oil and more inventive uses.
They also mention a strong smell after using it.
So my questions are:
Did you use it?
Gas tank only or engine oil, vacuum lines and so on?
How bad is the stink and how much it lasts?
Anything I missed mentioning that I should be aware of?
Did you use it?
