Shudder when engaging clutch
fb6 I recently began hearing a groaning noise when I engage the clutch in low gear... sounds like the noise metal makes when Superman bends it.
Sent from my SM-G955U1 using Tapatalk
Interestingly enough, I had a new clutch fork, slave cylinder rod, release fork bolt, release fork spring installed and the clutch bled. All seemed good after, however a slight shudder/vibration has returned, albeit not nearly as bad as before. Could someone by any chance show me their stock CMC adjustment on their R18 and maybe a look at the slave cylinder as well? Just want to compare some things.
