Stock Nav. Radio into Non Nav. Car
Discussion in 'Navigation, Security Systems, & Electrical' started by Balt15Si, Jan 9, 2019.
  1. Balt15Si
    Balt15Si Member
    28
    I've read all the posts about this on here, great stuff, but I didn't see it mentioned anywhere about the navigation antenna, so going from a non nav Si, with premium sound system ( sub ) to a navigation radio from another 15Civic, will I need the navigation antenna? Anything else I may be missing?
  2. webby
    • 2018 Toys For Tots
    webby Administrator
    48,960
  3. webby
    webby Administrator
    48,960
  4. Balt15Si
    Balt15Si Member
    28
    Thanks Webby, and where would the security code be for the one that's in the car now? just in case I end up selling it to someone, they will need that right ?
  5. webby
    webby Administrator
    48,960
    could be a card stuck in the manual, or commonly a sticker stuck on the side of the glove box. If you don't have it, you can get it from your vin/serial # on the radio
    https://radio-navicode.honda.com/
  6. Balt15Si
    Balt15Si Member
    28
    Thanks again Webby
  7. Balt15Si
    Balt15Si Member
    28
    I just read the owners manual and it says if the battery is disconnected that it shpushoul be necessary to put a security code in , but the Nav unit I bought does have a security code for it
  8. webby
    webby Administrator
    48,960
    I’ve seen others claim a quick battery disconnect didn’t cause issue, but I’d imagine after a certain amount of time it will need it.
Share This Page
