Tools needed for camber kit?
FTSEvan
18
West Palm Beach
Got my SK2 camber kit today, gonna be putting them on tomorrow night. Just wondering what tools I'm going to need to bring home from work to put them in. Thanks guys
Wrench/Socket set, torque wrench, breaker bar, and a monkey wrench (for adjusting the camber arm). As well as penetrating oil and anti seize lubricant. Be sure to apply anti seize on the threads of the bolts/camber arm during installation.
Per side:
1x Rear knuckle bolt torque spec = 65ftlbs
2x Upper arm bolt torque specs = 44ftlbs
Per side:
Specifics on socket sizes? I like to bring home as few tools as possible
Take the part with you and double check if you can.
I believe you need a 14mm and a 19mm. It's been a while since I installed mine.
edit: collegehillshonda lists the upper bolt as a 12x86.5 but I don't know what the numbers are referring to. It could be a 12mm bolt instead of a 14. I highly recommend you test fit a couple sockets on there before you head home. Id grab a 12/14/17/19 just to be safe.
Yep all three bolts were 14mm, but of course there's always a problem when working on cars lol
unfortunately, procivic may have shipped me the wrong parts or, being as I received the parts in a torn open box, parts may have been "misplaced". Oh well, guess I'll have to wait until Monday to sort things out
Oh man that sucks. There should be some sort of sleeve included with that kit. But I wonder if it is fixed and keeps that part of the camber arm from moving out of place from the middle or not. If it moves back and forth, alignment will keep fluctuating(camber and toe) from just driving the car.
I wonder if they have changed the rear control arm and knuckles for the 14/15' that the older arms don't fit.
No, it's the same. That's just how the new Skunk2 camber arms with the spherical bearing looks like. I think there is supposed to be a metal sleeve going through it.
