Jake Joiner
- 1
Halp
Is the fuse blown? Are all your grounds secure and touching metal?
The fuse that the battery goes through looks fine, and the interior ACC fuse, which the fog light switch is most likely fine seeing as it still illuminates the switch. There's a possibility my ground for the fog lights isn't true ground, but the other one is connected to the negative on the battery. I just don't understand why one worked then nothing. And no, they're the halogens that were included but I will probably change them out eventually.
I think that might've been why they both stopped working, because at the time the relay wasn't kicking on.Just a heads up, I had an issue with where the wires plugged into the back of the switch. It was loose or whatever, but when I moved the plug a certain way everything would stay on. So I taped the wires on the side of the box in a way that it kept the connection and put a thin piece of cardboard to make the connection secure. I've had no issues since.
