Tony-si
I know there is a cabin filter and one more. Who makes a decent one as my filters need of replacing.
Cabin Filter #1: Fram CF10134 for Civic 2.4L Si
Cabin Filter #2: K&N VF2001 for Civic 2.4L Si
Air/Intake Filter #1: Fram CA10359 for Civic 2.4L Si
Air/Intake Filter #2: K&N 33-2473 for Civic 2.4L Si
I have seen the fram is.there are a lot of them-I suggest buying three at a time, some of them are scented too.
from the dash.What kind of vibration and where? You could have a leaf in the fan.
does it without the filter in it as well. i took the old one out slowlyIs the filter loose in the frame? Maybe the wrong filter?
from the dash.
I can not see in side. not fit my hand in to feel. should i get a compress air can and shoot it in there?Did you look in the fan to see if it had debris in it?
ok so I installed the fram cabin filter and when I turn the fan on there is a vibration. Does anyone know what could have happened?
I took it out slowly and put the new one in. blah56I actually had a very similar issue the same week I got my car. I ended up taking it back in and they said that there was debris (leaves and shiz) in there between the fan and filter areas.
Where would this be?You can drop it out to look inside and clean it easier. I believe it is only 3 screws that hold it in.
