Eddie Blanco
- 654
Sweet brotha! I think we have the same setup as far as mods (injen intake and exhaust)....I am eagerly anticipating your opinion on the downpipe!
One thing I should mention to those of you who are gonna install the dp yourself, you will need to have an 02 sensor socket to get the primary (top) sensor out. Honda put an aluminum cup around the base of the sensor so you cannot put a 7/8" wrench on it. Also I have a Matco 02 sensor socket and it was too thick to even fit inside the cup so I had to grind down the outside of the socket to get it in there. Other than that just take all the heatshields off the stock dp, unbolt the secondary 02 sensor wire harness bracket on the firewall, and unbolting the the b pipe heatshield gives you enough room to get that sucker out of there. You have to twist it out of there in the right direction, will take you a few min to figure it out.
You didn't have to take off the coweling? I have read and seen pics that you have to remove that stuff too?
Actually, no...
The UR loses quite a bit of torque to the stock car below 2700 rpm...that's something you CAN feel in daily driving (I know I shift before 2700 rpm). Also, UR made the 11 lbft of torque gain with the addition of a 3" exhaust. These guys made it with the stock exhaust. Imagine how much more torque you'd get with the addition of an exhaust?
dyno pic?No i don't. Still over 160 ft/lbs
Even my low cam is over 140 ft/lbs lol.
