pssstitsmike
- 105
ThanksIt finally showed up on this browser....... I tried G-Chrome but couldn't log on .....Forgot my secret stuff(password). I write them down usually but can't find this one. And, it wouldn't transfer to the other browser, no wonder I don't get around to changing browsers........
Anyway......... The light mod looks sweat.
Got it from carid.com 120$Did you buy this kit from ebay?
Wiring was super easy. One white wire to battery 2 black wires to ground and run the green switch wire and switch harness through the fender firewall. Green switch wire can go to accessory fuse using add a circuit. Hardest part was getting wires through the firewall.was the wiring difficult? have any pictures on wiring?
cool. U will like it. If u have any questions you can message me. Make sure you buy the add a circuit to mini fuse to tap into accessory for the green wire. Other than that it is simply 2 black ground wires and white power wire goes to battery. Make sure you buy a terminal connector to hook it up to the battery. Good luck with the install. Takes about 3 hours from start to finish. The bumper is easy to remove. Its just 12 clips on the bottom 2 screws on each side near the tires and two screws on the grill n a few clips thereCool! Just ordered mine =)
