- 57,188
- 24,270
you can see at least one pic of the adjustment in this diy
http://9thcivic.com/forum/threads/redshift-koni-swift-8thgen-combo.4225/
See I knew you would help me out with finding that thread! Thank Web!you can see at least one pic of the adjustment in this diy
Koni Adjustment Location:
Front - shock adjustment is through a little plastic door under the hood in front... not a big deal and can be done in a matter of seconds.
Rear - shock adjustment is done from inside truck. once rear carpet is pulled back, the adjuster is right out in the open. Sedan and coupe are the same. If you want to change the rears all the time, just get used to pulling the carpet fasteners off. Again takes a few seconds and not a big deal at all.
Chris
(bro hug)
Chris, would you happen to know the motion ratio of the 9th gen suspension?
OK so before seeing this thread I was going to go with the Eibach Sportline kit when it gets released and stick with the stock strut/shocks.Did any of you guys check out Redshift:
http://www.redshiftmotorsports.com/RedShift2012CivicSuspPackages.htm
They have a lot of options that cater to different needs. I really am keen to know how the spring / shock combo works see as that was such a great package on the civic si.
Awesome feedback Chris!Hi Jonny,
Going with a Sportline kit on stock shocks is definitely the best option for stay on stock shocks, and it's easy on the wallet. But you have to decide if you want more than that. The Koni shocks really make a huge difference. And you can pair them with anything. So, it really depends on what you want to do and what you have to spend. The coilovers are great if you plan to track the car and want to be really fast or if you really care how high the car sits. And you can run whatever spring rate you want; so it can be performance oriented or more comfort oriented.
Also, you may want to consider the Konis with drop springs of some sort...that's a great option too if it's really mostly a daily driver.
Chris
What I really want is 1st the ride height that looks the best but still functional for daily driver. 2nd a car that can turn and go around corners as fast as possible. I love going around corners fast!! 3rd something I can maybe take on the track or autocross and kick some *** and have a blast doing it.
Would you happen to know if the make them for the 9th or do I have to get them for the 8th?I don't like most of the cheap coilovers. The Koni shocks are really key to a good handling car. If all you want to do is lower the car, then there are some coilovers that will work. But if you want something good, I would recommend Konis on the Skunk2 springs.
Chris
