Arm0ged0n
lol once I'm do for one, sure.Those syringes blow.
http://www.8thcivic.com/forums/transmission/301253-diy-manual-transmission-fluid-change.html
Maybe Arm0ged0n will let me do a DIY using his car.
__________________~50k, didn't worry or diagnose until it got louder at ~70k.
The person rebuilding it said I must never shift hard or race based on the synchro wear and final drive bolts being in good shape, but all bearings inside were toast. The only thing I could attribute that do is amsoil mtf for two fills, being used from ~15k miles until about ~60k miles, changed over at ~40k miles.
I am now a firm believer in the OEM fluid. Fresh fluid, to me, feels good regardless of manufacturer.
what kind of fluid did you use from redline for your manual trans?
____________How many miles have you put on your MTF? I want to compare a UOI of amsoil and the oem fluid.
Yep... that's the one for my 2012 SI as well.That's the recommend weight from
Redline web page..
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
___________________That seems extremely heavy. Honda is close to a 10w30 and Amsoil is a 5w30
So does this mean that we should change the trans fluid below the recommended mileage (around 50,000 miles) for a better longevity?____________
I'm on it.
First, great idea on the comparison. My car is a 2012 with just 3,000 miles on it, although will be driving from CA to PA and back in May -- 7000 miles right there. I changed out the OEM fluid after 1000 - 1500 miles. I'll run a sample of the Amsoil through the lab in March (for a late baseline) then after my trip, followed by a test every 5,000 miles until Blackstone gives me a bad report. We'll find out exactly how far the Amsoil can go. (Although there will be roughly 4oz of makeup MTF after each sample)
We'll just need somebody else to test a different fluid... preferably the OEM. Somebody once made the comment that this gearbox will destroy any fluid you throw at it. Now we have a reason to think that might be true.
____________
I'm on it.
____________________That's the recommend weight from
Redline web page..
___________________
You are correct, sir.
http://www.amsoil.com/shop/by-product/transmission-fluid/manual/
Makes me wonder who's right... Amsoil in recommending a 5-30W or Redline in recommending the 70/80W. Amsoil does, in fact, carry the heavier weight fluid as well. Maybe some Hondas take that one...
___________________________So does this mean that we should change the trans fluid below the recommended mileage (around 50,000 miles) for a better longevity?
_____________I am figuring that cause Redline is a synthetic they want a heavier weight then recommend to make up it.
If you can still shift at 50k let me know, cause I made it once to 40k once on stock fluid and could barely get the car into 1st and 3rd, I can do 40k now on Redline with no problems unless I really drive the car hard...
Perhaps. I like the way you think!
But we could only draw that conclusion after a lot of testing and research, which takes time we don't have. Keep in mind this entire discussion is based on one person's unfortunate experience. Without verification of lubricant failure we have nothing to go on but speculation.
For now I would simply change fluids in accordance with the manufacturer recommendations.... although you may want to send in a sample. I know I will be. It's one thing to wear out a clutch after 100,000 miles.... but i'd hate to lose the entire gearbox.
_____________
..... is 50k really the recommended interval? Wow. Given how easy it is to change I was going to change mine every 2 years or 15,000 miles. (a fanatic, i know)
Although a gearbox is an enclosed unit, any lubricant still deteriorates because of HEAT. As a rule the hotter something runs the faster the lubricants fail. And Hondas can run very hot.
I changed my trans to Amsoil at 40k miles. My car is currently 55k. Lol.If you can still shift at 50k let me know, cause I made it once to 40k once on stock fluid and could barely get the car into 1st and 3rd, I can do 40k now on Redline with no problems unless I really drive the car hard...
____________
I'm on it.
) I honestly felt no difference in shifting after I changed it.I made it to 110k miles on my '03 Civic without any problems. (stupid me thought MTF was part of the 100k no service requirements) I honestly felt no difference in shifting after I changed it.
